Hi! I am trying to use and connect a “T3-BB” in a “Sunfull/Milesgo HMI i7-1031” using X2View Software. Anyone had an experience using this setup? I am configuring in protocol BACnet IP. Points have been extracted using BACnetScan and uploaded it to the X2View, but when running the X2View, it cannot connect the points. Thanks!
I am not familiar with the Sunfull HMI but you could send a few screen shots from T3000 and in particular Yabe which is under T3000 → tools → bacnet tool. If yabe can find the objects your HMI should be able to as well.
One thing to be aware of is that T3000 inputs, outputs, varialbles and so on need to have the range set to something other than the default which is unused. Once you configure the range they can be discovered as Bacnet objects.
Final note: Yabe needs to rescan the network after making any changes. It doesnt automatlcally update the objects till you go through a new discovery process.
