Hi There,
I had a working system with graphics that had multiple data points on them. I recently updated the T3000 software to the latest (sept 29) and then all the elements went away. I can rebuild them I suppose, but anyone else had this happen?
Jim
Could you share a few screenshots so we can look into it? It looks like there may be a loading issue with the older data.
Ok, here are some snips. Not super revealing. Prior to upgrading T3000, all the data points were there. After upgrading, the points all disappeared, and the element count seems to vary. Sometimes it is 0, sometimes it can be 6 or 11. Random. but no data points show up on the graphic anymore.
I would go completely to webview, but I can’t get it to save my background image to the user objects tab so I can put it on the webview graphic.
Thanks for sharing. I’ll check it and get back to you later.
anyone else seen this? Live project. Customer not happy that graphics are now broken.
We’ve identified and fixed an image loading issue. The fix will be included in next week’s release.
If you’d like, you can share your remote access details, and I can help apply a patch before the official release
The varying element count (0, 6, 11) sounds more like the graphics file or objects are failing to load than the data points being deleted, so rebuilding may be wasted work. I’d test the patched build on a copy of the project first, and keep a backup of the current database before applying it to the live customer system.
