Bas wire sheet
Hi everyone,
I built BAS Wire Sheet, a Home Assistant integration for working with TEMCO controllers. I wanted a visual way to trace BAS logic, see live point values alongside the logic, and work with T3000 Control Basic programs from the same panel.
With BAS Wire Sheet, you can:
  • Build visual logic sheets by connecting blocks and simulate them before deployment.
  • Browse TEMCO inputs, outputs, and variables in the T3000 Explorer.
  • Import supported T3000 .prog files as editable wire sheets and compile supported logic back to Control Basic.
The project is open source under the MIT license. You can add it to HACS as a Custom repository under the Integration category. The README covers installation and configuration.
GitHub repository
If you try it, I’d appreciate hearing which TEMCO model and firmware you’re using, what works for you, and where the workflow could be better.
Thanks,
Carlos
Will check it over ASAP, I used to do shop drawings for projects and know how much we can benefit from this. Was working on the first steps of this myself just yesterday, a graphical version of the hardware and the current state.
I will be glad to cooperate closely with you in the next steps.
Thank you! I’m really glad to hear that you’re working on something similar.
I started this project because I wanted an easier and more visual way to work with TEMCO controllers. There is still a lot of room for improvement, and I would be very happy to collaborate with you.
I really like what you’re working on, and I think we could share ideas and build something useful for the TEMCO community.
Looking forward to working together!
