Have some old valve actuators that use a 0-11vdc signal range in lieu of 0-10vdc. Is there any way to increase the analogue output voltage to 11vdc?
You could add an op-amp to increase the gain to 11 volts but seems like a lot of work for a 10% voltage increase.
